- Middle Tennessee
I've been thinking about upgrading the front D30 in our Grand Cherokee. When I had it aligned, they told be the stock ZJ D30 had a bit of a bend to it. I also found a Ford 8.8 rear diff with an open case with 4.10 gears. So I'm planning to swap in it eventually.
I've been eyeing JK wheels and really like the stock steel, Rubicon, and some early JK aluminum wheels. So keep this in mind as I'd need 5-4.5 to 5-5 wheel adapters.
So this got me to thinking why not throw in a WJ front axle? It would get me the 5-5 bolt circle, crossover steering, and bigger brakes. The downside is that it is a low pinion.
Then I started thinking of going with a XJ D30 to get the high pinion. This would require swapping in all the WJ outer steering, knuckles, etc. The advantage would be I could now use the WJ unit bearings and the rotors which would have the 5-5 bolt pattern to work with the wheels I've been looking at and have the high pinion for strength. My question would be on this, do I need to use the unit bearing spacers? I think since I'm using everything WJ out, the spacer problem isn't necessary since I'm not mixing XJ/WJ outer parts.
What would you do for the axle? This ZJ is a DD/mild trail (gravel roads and dirt trails) rig and will probably end up running a 31/1050R15 tire with 4.10 gears. I'm thinking of just going with the WJ front as they are plentiful and would just swap in, correct? Low pinion wouldn't be a big deal with only 31's.
