DrRandy
- B'Ham Alabama
I picked up a HP D30 from a friend a while back. He had OTK steering and OTA track bar mount so his geometry was fine. Not mine...i have bad death wobble and bump steer. I removed the steering stabilizer for pics.
I'm running Currie steering so my track bar needs to be lower on the axle end to keep parallel with the drag link. On this pic i cut and ground down the current OTA track bar mount and i'll re-drill to track bar lower. Also, i'm running the RE 1665 HD Trackbar bracket on fame side
My question is when I make the track bar i need to bend it to keep it from hitting the diff cover. Where do i want to bend it to keep parallel? Should i bend it like this
Any recommendations would be great thanks!
