HodgePodge
NAXJA Member #987
- Duluth, Minnesota
Well, I'm getting ready for the winter projects already. Started gathering up parts to build up my RENIX based stroker. I have chosen to go the long rod route. Just because I can dial in the Quench and CR.
Right now I'm looking at the following:
258 Crank
Recon 4.0l Rods
Custom Pistons (undetermined at this point)
Melling high-volume oil pump
Cloyes Double Roller Timing set
Mopar performance Valve springs,locks,retainers
Performance Cam (undetermined at this point)
I haven't seen too many people using the JRE pistons and wondering what makes them different than the Accurate power..
JRE is available in .030 - .060 overbore with 0- 30 cc dish and has 4340 Press fit pins, Ross Racing Moly Rings included. For $550
While your Accuate Power comes in a .030 over bore with a 23cc dish and comes with pins. Rings are seperate. For $600
Does anyone know of a significate differance between the two?
Hodge
258 Crank
Recon 4.0l Rods
Hodge
