Cup holder mod
Sub Zero
Arizona
Got tired of my cup holder falling off around turns with drinks in it. I wanted to countersink the holes to clean the look up, but I didn't have anything big enough. I wanted to use different hardware too, but the tube for the rear vent is in the way unless you pull the center console out. Doesn't look as factory as I would like, but it's functional. There is enough tension on the lower arm that it should never pop out.
Nice job. A 97+ console works also.
I was able to use a single self tapper on mine. Its held 2 large energy drinks over rough terrain without failing.
Sent from my SM-G892A using Tapatalk
