dingo151
- Moscow, Idaho
Hi!
Simple question.....was cruise control available on a 5 speed XJ?
Thanks!
Dean
Thanks!
Dean
Dare I ask what the second lever is for on the shifter?
yes, it was available. IIRC there is special programming in the ECU to handle things so it doesn't peg the rev limiter when you clutch in to upshift? I'm not sure on that.
I didn't think the 96 and down 4.0/ax15 had a clutch safety switch, which is why I'm a bit confused about this. I know that some 97 and up vehicles do, since I pulled one at the junkyard, but not sure what exact year that started.every 5 spd vehicle I've ever driven with cruise simply turned off the cruise when you hit the clutch, same as stepping on the brake pedal.
