Cruise Control Swap
karstic
Milwaukee
So I have a 92 with no cruise control. There is a 93 in the local junkyard with cruise control.
So now the question.
Will the 93 components work in the 92? What are they components?
I know there is the vacuum actuated servo mounted to the passenger side firewall and the turn signall/cc lever on the steering column. Anything else?
There is a switch at the brake pedal that shuts off the cruise (so that it isn't pouring gas into the engine) when you hit the brake pedal- this avoids having the engine pulling when you want to stop- kind of important. Ithink it is the same switch that unlocks the torque converter on an automatic tranny. Sorry I can't be more specific- I run a 1990 and a 2001, quite different.
