I checked the vacuum line to the canister and back to the servo. all fine. When I pull of the little line you can hear air coming in.
The plastic piece at the end of the cable is connected to the throttle. than a big line goes into the firewall (no idea where)
The cables at the level were broken and I repaired them.
Under the dash the cables go into a connector and in a yellow box.
What elese can I check or messure???
How can I check the brake switch or adjust it?
