Originally Posted by
seanyb505
What about 87-95 style cam and 1.7s? Im just trying to exhaust every option so I know I can be confident in my choices.
Doublehead said:
...if I understand correctly what I've been trying to read about camshafts, that might increase top-end horsepower on the cost of torque? Or is my brain just out to lunch?
You guys real got me, a wondering, about this....... so i pulled out my 'Dyno Sim' and set out to answer this question.....was quit surprised by the results.
First off, I made two sim eng that were identical in every way. stock 4.0 bore, 258 crank eng,(3.875/3.895) 7120 HO head, stock 92-95 cam, 9.1:1 compression, 500 cfm induction, and Tune- Port injection. Both had the exactly same numbers.
now i added or changed the lift form 0.424 to 0.451 (1.6-1.7 rocker arm ratio) to sim 1 and keep #2 the same........
there was no HP or TQ change at 1500 rpm and this was the real shocker, TQ was up by only 1 and the HP was also up BY 1.
There is also variables such as ramp speed that is not being considered in "default' mode (I'm not smart enough to change this,and under stand what and why i should change it.....so i just let it do is thing.)
So the answer, the best that i can figure it, going form a 1.6 to a 1.7 will not hurt the bottom end at all......and will gain slight on top.
I went and look at the flow number and found some of the answer why
the CFM air flow between .400" lift and .500" lift was only 3 cfm more on the int. and 5 cfm more on the ext. side.
A ported head would help on these numbers.
Flash.
