So, I removed the head on my 4.0 but I did not drain the coolant first. as I took out the last two head bolts, coolant started coming out of the gasket area. Upon removing the head I found all 6 cylinders full of coolant sitting on top of the pistons... I soaked it all up with paper towels... Is this going to be ok? What about the little side holes around the cylinders, they are full of coolant too, should I try to remove it or is that normal? Thanks for any suggestions. :cheers:
