There is no possible way a CPS can cause a high idle.
While I have been a huge Autozone fan for 20 years or more, I have seen a huge jump in off the shelf junk quality in Durajunk quality that was defective right off the shelf. So bad at times I had to switch to O'Reileys and NAPA for a part. I rarely use NAPA and O'Reilly because they are hard to deal with. But in the last 18 months I have found myself using Amazon Primer 1/3-1/2 of the time, and I always search the first now, or as one of several I search before ordering. I have found myself turning to Advanced several times the last 2 years a last resort and got good service and parts. In reality I have probably used a dozen parts/supply sources the last 1-2 years.
Walmart for tires and oil
Rock Auto
Advanced
O'Reilly
Autozone
NAPA
Even Ebay on occasion (I use to use Ebay a lot) But Amazon Prime is way faster, :clap: and easy to get refunds/warranty fast.
Amazon and multiple sellers there
and about 6 others on line for this and that part.
Not just jeeps....That have and work on
99 % of the time I never buy an OEM part or buy from a stealership, it's against my Religion,
LOL
I spread the wealth LOL
Bad parts I got the last 5 years or so from Durjunk, rebuilt CV joint, New Rear brake drum, so defective you could look at it and see the off center-ness, rear brake wheel Cylinders, one leak air in but not fluid out, drove me nuts for months trying to solve the problem. next one pissed fluid out trying to bleed it, switched to Wagner brand at NAPA, problem solved, Never had a bad alternator (rebuilt) from Autozone, or bad starter, but the water pumps are durajunk, we should make a list of bad parts sources????
Never had a bad TPS or CPS (Renix) from any source, as all the Renix CPS sources suck the same, LOL, need to Modified and moved closer to the teeth to put out a stronger signal. Solves a lot of other issues....
I no longer use any T-Stats on Renix jeeps other than Murray brand made in Isreal. I could spend all day writing this list.
Don't recall ever getting a bad part from Rockauto, wrong one just once over 10 years ago, but every one that problem, and they fixed me up right away. Rockauto freight is the killer for me, and get free delivery in 48 hours with Amazon, which is why I use them more and more and more. Fast and free delivery is changing the landscape fast. And I am noticing that several of the locals have jacked their prices way WAY up lately.
I can get $6 WSWiper blades/assy delivered free from Amazon, and the local stores want $20 and have go pick them up. I fear the day is coming where they may start to vanish. Hard to say, folks that need a part in hours may keep them going for a long time.
