Well if you went to Go-jeeps website you would see that your caster is off. Not alot, but not at factory specifications.
It really doesn't matter if your at 4" or at stock, the numbers needs to be the same or very close. The only consideration you can make is for your front driveshaft angle, but if you were doing that the caster would be around 4-5 degrees not 8 something.
