Apparently my 2DR cherokee has a 4.5" lift in it (procomp) but the rear leaf springs are damn near flat and all I see over stock parts is new ubolts and a 2-inch block. I'm thinking A) procomp packs that are now too saggy or B) I've been lied to
so what I'm after is if someone with the same (or close to) lift as me could measure from the center of the rear wheel to the bottom of the stock flare. I'm working on the bastard pack idea for the rear and I have what I've been told are RE 4.5" front coils. Those BP's end up being around $100 all said and done (new clips, pins, u-bolts and the springs) which isn't bad but I'm just about to spend $100 on new ball/u-joints for the front drivers side as I just found out it's dangerously sloppy and that has to take priority over getting the most out of my lift.
