I've removed the head like 3 times now maybe 4, each time its been something else.
Started off not knowing anything about this engine. I have worked mostly on DOHC V6 engines, and I'm used to all aluminum everything.
I replaced the head gasket originally thinking it was blown after overheating.. Cross flow between cyl 1 and 2. Replaced the head gasket. After reinstalling the head, still had low compression on cyl #1. Removed the head again. That's when I noticed a tiny booger on the side of piston 1. Turned out to be galled badly. Removed the piston and found destroyed rings. All new pistons and rings. Reinstalled the head. Still low compression cyl #1. Removed the head again and found that I had a burnt warped valve in cyl #1. Thats when I learned to test the valve seals using kerosene and watch for leaks. Grabbed a head from the junkyard, did a good lap job on the valves, and seal was tight on. Reinstalled the head. Ran pretty good, but you could tell one of the cylinders was not working as hard as the rest, some of the time. I chalked it up to one of the valves was rotating and sometimes it sealed good, and sometimes it didn't. I expected as much from a $50 u-pull-it head.
Then it started leaking. After trying again and again to seal the #11 head bolt, and going through bottle after bottle of coolant, at that point I was like to hell with it.
Oh, and new water pump, thermostat radiator, thermostat, A/C system vac/fill, new tires, repaired the broken sending unit. I'm just done. If a little crap in the system takes it to 'hardly anything seems wrong' at this point, so be it.
I've gone from barely runs, no heat, unreliable to I've driven it to towns hours away to doctor appointments and I trust it to do what it needs to do.
The 4 wheel drive system seems to be the most robust components on the thing.
Now it needs new shocks, new front wheel bearings, new front brakes, new front rotors, upper and lower ball joints, tie rod ends, new rear wheel bearings, new head liner, console fixed, A/C drain leak fixed, door lock actuators fixed, rear lift gate window pistons, probably a new turn signal bulb (it works only sometimes), replace the transmission filter and fluid, replace the fluid on both differentials, fix the flickering dash lights,.
Ya... i'm not too worried about a tablespoon of leak fix.
:roflmao:
