Control arm bushing replacement?
MJR said:
Well Jeff as I recall the early bushings had stamped indentations inside the bushing sleeve to use a smaller diameter bolt but the bushings have superceded 2-3 times since then. In 97 the axle end bolt was no longer serviced. Here are the specs for it. M10x1.50x75. The body end bolt is part # 6505153AA which is a M10x1.50x85.
The new bushings I have also have the stamps inside the sleeve.
Thanks for the part numbers and the info.
