Go to your device manager, write down all the hardware that is in there, model number of video card, network card, burner, right on down the line including the chipset stuff in the system area and usb stuff.
Make sure you have all the drivers for those cards and hardware on CD or floppy, if not get them from the vendors before starting this.
Wipe the machine, make a boot floppy with fdisk on it, delete the partition.
Reboot the machine, go into setup either thru the delete key or F2, set the bios so that it boots off the cd. Save and exit.
Stick the WinMe cd in and boot, then just reinstall the whole thing, after the OS is in install the chipset software first, disk drivers second, video third, then just start installing the drivers one by one that the OS did not recognize. Takes a while which is why I charge a two hour bench fee for doing this even though it usually takes longer.
Oh, and before you make your first internet connection make sure you have updated anti-virus software installed and running. Helps to download the latest version and signature files before wiping the box.
Where are you located ??
*sometimes* you can rerun the winME installer and reinstall, this keeps the files, drivers and stuff but you have to reinstall registered programs.
ME is a bi-annual operating system, needs to be done 2x a year
