montanaman
- Western Montana
- '91 xj,
- 4.0 HO
- AX15 with internal slave
- Nylon clutch line with "quick disconnect" which won't disconnect.
HERE IS MY STOCK ARRANGEMENT:
HERE ARE THE CHANGES I WANT TO MAKE:
I want to upgrade the nylon clutch line & quick-disconnect with a metal brake line and threaded coupler to attach the new metal MC line to the slave line. Advanced Adapters sells a kit for just this scenario, but they charge $75+ for it. I'd prefer a home-brew solution.
The problem is how to attach a metal brake line to the Master Cylinder. The MC doesn't have a threaded outlet ... the nylon line pushes into a smooth hole and is held in place with a roll pin.
I'm thinking to save about 2 inches of the nylon line where it comes out of the MC, and somehow connect that cut section of nylon to a metal brake line.
Any good ideas how to do this? Has anybody used a compression fitting in this situation? Would it work? I can get a compression fitting that adapts to 1/8" NPT, then convert the NPT to metal brake line and be good to go. But I don't know if a compression fitting would work properly with this kind of nylon line, or even if I could find it in the right size.
Or how about a barb fitting with some kind of special adhesive and a clamp? The metal adapter that pushes into the MC seems to be fitted to the nylon line with a barb.
Any other ideas?
Thanks.
- 4.0 HO
Any other ideas?
Thanks.
