- Henderson, NV
posting this here hoping to get some advice or experience.
I'm currently having some installation issues with my comp cams 68-232-4. This is the second 232-4 cam that I've installed into my stroker. last time I just installed it the factory way, dot to dot. Engine ran fine, however this time around I went ahead and degreed the cam when I installed the second time. I also made some solid lifters to check the cam.
With the stock timing set, I checked my ICL, and I came out with 114*. The Cam card says installed ICL is 110. So that would be 4* retarded correct? next just to see where my timing events land I went through and degreed them. Cam card says timing events are measured @ .050. When I measured them @.050 all my timing events were off by 25+ degrees.
I called Comp about this and their tech specialist says the card should have been printed with timing events @.006 not .050. So the card was wrong. I went back and measured the events again and everything was -4* retarded.
So I bought a JP performance adjustable roller timing set and advanced the crank gear +2* to get my 4* on the cam.
Rechecked my ICL and timing events and im at 110* installed, and all my timing events were within 1* +/-. all is good right?
But now it runs like crap. low vacuum, only 12in hg at idle, and im missing hard. tried adjusting the distributor to see if that would help but no joy. ( i know, computer controlled ignition)
Called Comp again and told them what I had done, and the only thing they had for me was "its impossible for you to get 114* ICL if you install the cam dot to dot, you will be happy with the cam if you go and install it that way."
My complaint is right now is, why even have a cam card then if they just want you to install it the factory way? Their instructions say right in the packet to degree the cam to get optimum performance out of the cam.
I went and ran the numbers on the cam through a cam calculator and they don't add up with the correct ICL, or duration.
Anyway, long rant, but im wondering if anyone else has had an issue with this cam as far as degreeing it vs the cam card. maybe I'm off in left field but I think someones numbers are wrong.
This is the specs of my cam from the cam card
valve timing
.050 ( actually .006)
-------OPEN ------- CLOSE
INT 13 BTDC -- 56 ABDC
EXH 62 BBDC -- 13 ATDC
Duration: @.050
INT -- EXH
206 -- 212
Lobe Seperation: 113*
valve timing
Duration: @.050
INT -- EXH
206 -- 212
