Command Trac questions
prljeep
Toledo, OH
1. What are the chances that my vacuum shift motor on the Model 30 axle needs replaced (does this part fail a lot)? It does not appear to be set in a fixed position, I can rotate it about 180 degrees. (I have replaced 90% of the vacuum lines- spray tested the 10% left for leaks).
2. There is an indicator light/vacuum switch located underneath the coolant overflow tank on the PS firewall. What does that do and can they go bad?
3. Is the Model 30 the same as the Dana 30?
4. Thanks
