Comanche 87 to 97
Knkn90
El Paso
hello all!
i'm planning this swap since a long time, this is my first project of this kind and I am learning in the process, hope you like it...
IMG_3935.png.html
THE DONOR:
I paid $ 900Dlls on craigslist for This 2wd 97 Cherokee With a nice running engine, bushwacker fenders, new tires, 17 "american racing wheels, 1" 5X4.5 to 5X5 spacers, new tires, stereo, and the tank full of gas...
I like that front bumper on the Comanche
Frustrated by not finding the original taillights at a reasonable price, I began a early project:
CAD design for the stainless steel tail light housing,
Then CNC laser cut the stainless steel
And making the final folds and measurements
Jeep Comanche tail light housing
So I finally decided to leave this project to the end and start the real work
Start the teardown
looking for rust
After seeing the rust that had the Comanche I decided to take a local paint shop and pay for an awful job, they only rivet a plate on top without removing the rust, For now I will leave it like that but in the future will remove the poor job that the paintshop did and I will remove the rust and put a new floor panel.
I buy the Comanche with the engine running perfectly even do the engine harness was not connected and instead of injectors it was running with a Holley carburetor
Start removing the Comanche front, fenders, hood etc...
Just buy this 1 ton shop crane at harbor freight for $100Dlls with a coupon that I have, it works great!
After a while I remove the screws from the transmission, a couple were hidden,
Next time I do this I will remove the engine and transmission at the same time
Engine, brake master cylinder, engine harness, heater box, power steering box, battery box and everything out
Also the interior was removed from the Comanche
And the pile of scrap is growing
Then I paint the engine bay with 3 cans of Duplicolor Engine Enamel with Ceramic and I will use one more can for the final touches
A few modifications in the firewall will be made in order to fit the new dashboard to the old comanche
This is the comanche firewall
and this is the cherokee firewall
The most notable difference is the location of the steering hole, this will have to be cut in order to fit the new 97+ steering wheel
Also this conversion is from standard to automatic transmission, so the clutch holes are no longer needed
Cut the plate in half for better manipulation
Then I use the brake master cylinder as a reference
Then I paint the difference with a black sharpie to cut it later
Cut the plate again in 3 pieces
After a while thinking in the method of doing this job I decided to use rivets instead of welding
Grey stuff is seam sealer, this works great!
This is how it looks from the outside
I apply more seam sealer in both sides after taking the pictures
