Comanche 87 to 97
Then I spray paint it for a better looking finish
This hole from the right side of the truck where the old antenna used to pass is also no longer needed so I use 2 washers, a rivet and seam sealer
I didn't take pictures of this process but what I basically did was drill the spot welds from this two brackets from the Cherokee and attach them with rivets in the same location in the Comanche
This two brackets will be the support of the dash and steering wheel support.
The left side of the cabin, (where the comanche parking brake is) needs to be modified in order to put the steering wheel support,
This is how the comanche looks like
And this is how the Cherokee looks like
So what I did was remove the screws from the comanche, place the cherokee steering wheel support in the bracket that I just install and drill the holes to install new hardware
This is how it looks
And this is how the bolts looks from the outside
Dash in for measurements...
Top left side
Top right side
Note that the holes for the screws do not match
I'll be cutting the dash support of the Cherokee and again attache it with rivets to the Comanche and screw the dash on
I forgot to take pictures of the heater unit install but is almost a bolt in, only 1 hole needs to be drill
After days of measurements, cuttings, riveting and drilling, the dash is finally in place
Also to connect all the harness for the dash took a lot of time to complete,
I'm trying to match this 4WD AW4 from a 94 XJ to my 2WD 97 harness, I read in this article http://www.naxja.org/forum/showthread.php?t=1053970 that only need to "cut and splice the wiring harness connector" so that's what im going to do...
Before I start cutting the connectors, I remove the 94 gear position sensor and put the 97 in place, I'm also using the same oil lines.
Turns out that the colors for the wires of the 97 and 94 transmission are the same, I just cut and match the wires,
Note that the 97 does not have 4X4 indicator so 2 wires are left over without issues
Follow me on twitter! @knkn9
