Re: The Colorado BS thread
River - Things are tough all over.
Last month my daughter took her 2013 JK to Larry Miller Jeep, in Thornton, for an oil change and a similar situation happened to her. The day after the oil change I noticed a dozen or more oil spots on the garage floor. I climb under and find everything tight but oil is dripping from the front stabilizer to the transmission cross member. It is also sprayed all over the underneath side of the engine cover and the hood. I assume the oil tech stuck the oil nozzle in the fill hole, then turned around and turned on the pump but the filler popped out of the file hole.
So I take it back to the dealership to pitch a fit. The service manager starts to say: well, it could be a cracked oil filter housing, blah, blah blah. I told him to go ahead and check that if it will make him feel better, as I knew it wasn't cracked, because I already checked. They also said they added dye to the oil so they can find 'the leak'.
Long story short, I had them steam clean under the hood and the entire undercarriage.
But I got the last laugh because two weeks later I traded in that JK to them for a new JKU.
