mgonos
- houston, tx
Re: The Colorado BS thread
-42 here at 8:30, wind chill -47. it's cold in granby...
hahahahahahhahahah. that was pretty good!!!Murphy's wife was having a baby, finally she delivered and the doc held the baby up and said look you got a little boy, but hold on theres another one he held it up and announced Murpky now you git a baby girl; but wait one more is coming , it turned out to be another girl,, Finally there were no more babys. Why so many babys asked murphy ,The doc said its something that happened during conception. After going home Murphy asked his wife remember when we made love and we were out of ky jelly and had to use 3 in 1 oil Yes said his wife and i'm sure glad we didn't use wd40
Bad news: The radiator in my little truck froze, along with the heater core. I've never seen the temp gauge read that high.Work today.![]()
If you have cranked it that much you are for sure flooded. Get a cheap set of champion spark plugs and install them. Before you actually put in the new plugs, and after you pull the old plugs, press the accellerator to the floor and hold it there while you crank for a few seconds to dry out the cylinders. Then install the plugs and have a go at it. You might get away with reusing the old plugs but the cost isn't that high and it never hurts to have fresh sparkplugs.
If you do this to clear the cylinders, be sure to move the spark plug wires well away from the spark plug holes before you crank it. Unless your plan is to fix it with fire. That air/fuel mixture is very flammable. Don't ask me how I know. :flame:
Need some car advice...
Have a 1992 Paseo, just got the motor mount fixed and they did the cap,rotor, and wires at the same time. I told them NOT to do the spark plugs cause I did them when I first got them, but they said that I needed Genuine Toyota Plugs for the car to run best. That the Campions that I put in do not get to a hot enough temperature. They said that I would get better MPG's if I changed too, if that was true it would be totally worth it!
Should I call this BS and keep in the ones I have? Or go buy some new plugs from Toyota?
A new XJ at the Park-N-Ride today
Who's ever that is, I always see it parked in between the spa and GoodTimes off of 92nd and Wadsworth
Saw this and thought you guys would enjoy it:
http://www.nbcdfw.com/weather/stori..._Icy_Loop_12_Dallas-Fort_Worth-115081734.html
