I did find the conversion workable, and I was able to do most of the work (replacing parts!) myself. I did the conversion in three steps -
1) Take XJ to local AC shop (same place I get my radiators) and have the "purge" the system. I told them it would not be necessary to pull a vaccum on it, as I was going to open everything up anyhow.
2) Replace parts. Reciever/Drier, orifice tube, LPCO switch (it was bad anyhow,) and seals. NOTE - I got the Everco kit thinking they'd have it all sorted, and everything I had was O-rings. I wound up pulling all the orings and taking them in to be matched. Check you system first - if it looks like flare junctions, they are probably orings. Make sure to use aircon orings, as everything else will come apart on you!
3) Return to aircon shop, report work performed, and let them purge and charge system.
I think the total cost, with me doing most of the labour, came to about $300 - but I get good prices on parts and I get a break from the very few shops that I use, because I send them as much business as I can. I could expect 2-3x that if I paid them.
The key is replacing anything that will not fluch out completely - the two lubricants are incompatible (it's not the refrigerant, it's the oils) and will cause system failure if they are not purged completely. When I talked to my shop before I got started, they told me that replacing the orings would not be strictly necessary, as they don't soak up enough oil to be a problem, but I changed them anyhow. The liners of the hoses are basically non-porous, so that's not a problem. You will run into problems if you don't change the orifice tube and the reciever/drier, as they do not flush all the way. The evaporator and condenser will flush completely, and they will work well with the R134a in my experience. If you are willing to put the time in to do the retrofit correctly, it's worth the time (especially if Freon goes the way down there that it did up here!)
I still need to dig for a newer coolant, if it exists. I suppose I could be imagining things... If I find anything out, I'll be sure to pass it along.
Also, make sure to clean the surfaces of the evaporator (near the heater core) and the condenser (especially - in front of the radiator) as those surfaces being dirty will quickly degrade the efficiency of the system!
Where in Mexico are you, anyhow? Just wondering...
5-90
