Coil Bucket Locations
Starboard M
Lafayette, CA
I am most likely over thinking these things, but bear with me for a second.
I am doing a front 44 swap, narrowed to waggy width, with TnT truss, etc, etc.
Unfortunately the TnT truss makes the track bar rather short, so I was planning on taking the axle side track bar mount off, and making a new that mounts farther off to the pass. side.
Here is a pic of the mount provided on the TnT truss, taken front Caged94XJ:
I was going to just take the mount off, and make a new one farther over. That puts it in the coil bucket, and I had the novel idea of simply flipping the coil buckets to the other side.
I was all set to do this, and then my Dad reminded me that that would change the coil location, and coil angle.
Let me see if I can explain this.
-Stock coil location, and the coil buckets provided with the TnT truss, mount the coil forward 2'' centered from the center of the axle tube.
-I want to flip the coil bucket plates, which would put the coil 2'' behind the axle tube.
-Or, center the coil spring over the axle.
Assuming I keep the wheelbase the same, this will effect my coil angle, moving it from about a 10* angle from vertical, to something that will be closer to 0*.
Is that going to cause problems, or is that fine and dandy?
You may have to cut the upper bump stop "post" and bend it back toward the cab a little and then reweld it. I believe Jes had to do that and so did I on the last build. Other than that, I wouldn't see much of a problem.
Billy
PS - Nice shoes skater boy. :cheers:
Billy
We were mainly just worried about the suspension having to travel forward and then up when going under compression.
Sounds like its not a problem then.
Don't move the Track Bar bracket. I am running the TNT setup with there track bar mount on JK axles. It works perfect. No Bumpsteer, No Steering stabilizer, No Swaybars, and I can cruise down the freeway at 75 with no hands on the wheel. I have 7" of lift and 35s.
My plan is to do this thing right the first time, so Im ok with doing just a little bit more work. Besides, its to late to turn back now!:greensmok
So what is wrong with the shorter track bar? If it is at a good angle, like TNT places it there is no problem with the length. I don't think you need to go through all the extra work, but what do I know.
So... how'd it turn out?
Billy
Skater boy had to go back to school.
I ended up ordering a 7/8'' heim for the axle end, and a JJ for the frame side of the trackbar. I got the axle in place, the frame side trackbar mount mocked up, and then I had to leave.
I started out putting the coils in the center of the axle, and had to move it back a couple inches to get everything space on the axle end.
I do have a question though. Is it better to have the track bar that is as long as possible, or have it be as close to the same length as the drag link
