Clunk/lurch into Drive, but not Reverse
soyjer
California
I just bought a stock 1999 XJ, never been off road or abused, never towed anything, 97K mileage...all u-joints, engine/transmission mounts, leaf springs, etc. seem good, idles about 775 rpm...and yet it clunks and lurches when put into any FORWARD gear, but NOT AT ALL WHEN PUT INTO REVERSE.
Has anyone else ever experienced this ASYMMETRICAL clunk/lurching on their XJ?
The only thing in the drivetrain that I can think of that would be affected differently going in the forward direction as opposed to the reverse direction would be the transmission itself...but the noise seems to be coming more from the rear end.
Is there something about the way a differential is built that would cause it to clunk in the forward direction but not in the reverse direction?
When the transmission is in neutral, how much play is there in the rear differential?
Might also be a bad transmission or engine mount.
Have someone shift the trans from drive to reverse, while you look under the Jeep, to see what's moving.
With transmission and transfer case both in neutral, I'm measuring 4.5 degrees of play on the rear drive shaft (2.5 mm or .1").
(2.5mm play / 200mm circumstance) x 360 degrees = 4.5 degrees of play.
I've had a friend switch between reverse and drive while I was under the rear end, and the only thing for certain is that it never clunks going into reverse and always clunks going into drive.
I should mention that the 2.5 mm of play was measured using my own two arms to jerk the drive shaft back and forth as hard as I could.
I wouldn't worry about it. With most of the 7 Cherokees I have owned the AW-4 transmission kinda clunked or lurched when switching between Reverse or Drive. The AW-4 is a firm shifting transmission, the unibody transmits noises very well, and any wear in the drive-line or differential that creates noises, is amplified. My 1998 has 280,000+ miles and the only transmission or differential service work has been regular fluid changes.
I wouldn't worry about it. With most of the 8 Cherokees I have owned the AW-4 transmission kinda clunked or lurched when switching between Reverse or Drive. The AW-4 is a firm shifting transmission, the unibody transmits noises very well, and any wear in the drive-line or differential that makes noises, is amplified. My 1998 has 280,000+ miles and the only transmission or differential service work has been regular fluid changes.
Thanks for the info...did any of the 8 have a low idle speed less than 750 RPM, and if so did they also clunk/lurch when put into drive (but not reverse)?
I haven't been able to locate any documentation that specifies what the idle speed is supposed to be except for the factory service manual that mentions 13psi oil pressure at idle speed 600 RPM... But 600 RPM doesn't seem to be the idle speed that most people in this forum are seeing with their XJ's, and so I'm not sure that 600 RPM is correct.
I'm also not seeing posts from people who had a clunk/lurch only when put into forward gears and never when put into reverse... I'm hoping that the fact that mine is completely asymmetrical will help me to figure out which component is causing the problem, but I can't find anybody yet that has had this clunk/lurch only when put into forward gears and never when put into reverse.
750 rpm plus or minus is what I would consider normal idle speed. I do find that pausing in NEUTRAL when changing from D to R or R to D reduces and softens the clunking. Maybe the pause lets the pressure in the AW-4 go down a bit.
As suggested, a clunk is somewhat normal. If there are no metal sparkles in the gear oil, and no chunks missing from the gear teeth, and the spider gear cross pin is tight, it will be fine.
Don't forget you are driving one of the finest examples of 1980's AMC engineering. Noise/Vibration/Harshness was not a huge design consideration.
They all clunk into drive regardless of good or bad condition. Certain angles help but like Tim said. Best bet is to just give it a second to spin down. Also don't throw it into gears. These transmissions are not delicate or prone to breaking and Jeeps are not the only cars that clunked into gear. Yours may have been made in the 90's but motor trend had already reviewed it as part of the 1984 AMC line up in 1983. It's not a modern vehicle
I jacked up the rear end today and grabbed ahold of the rear wheel and pulled it in and out, and there was very noticeable play (and another interesting clunking noise, of course)...so now I have another clunking noise and play where I don't know whether it's normal or not.
My neighbor was implying that I was applying Japanese tolerance standards to an old American vehicle, which is an exaggeration, but I'm starting to think that if you pull on the rear wheel and the drive axle doesn't actually slide out of the differential, you give a thumbs up and hit the trail. I don't mind the clunks, I'm just trying to establish when I should ignore a clunk and when I should take care of it to avoid further more expensive damage. I think I need to join a local offroad club so I can get some idea of which kind of clunks to ignore and which to take care of soon. ☺
Normal.
I spoke to an ex dealership Jeep mechanic, and he said the spec for that In-Out play is .070" max. Mine on both rear wheels measured >1/32" (.031) and less than 1/16 (.063), so in fact it does fall within the .070" max spec.
Amazing how the brake drum acting almost like a dull bell can make that little bit of movement sound so loud.
I also had the ex Jeep dealership master technician take a look at my clunking lurching problem when shifting into drive, and he said that it definitely was excessive compared to all the other XJ's he has dealt with, and he said it was almost certainly the transmission because the driveline looked tight otherwise and because it does not happen when I shift into reverse. I'll post back here again next week when the transmission shop tells me if it's the transmission or not.
Just have a minute to chime in. Have you checked your mounts? I had a weird clunk 20 years ago on my XJ and it was actually the exhaust support at the cross member coupled with the other mounts. I don't remember that much about it but it did it only in one direction.
Good Luck.
FOLLOW UP: Just got my XJ back from the transmission shop. It was in there for over 2 months, during which he completely rebuilt the transmission and the torque converter, replaced the valve body and the transmission control module and even the transmission case, and at the end he said that he and all of his fellow transmission shop owners on a network were all completely stumped as to why none of that fixed the problem. He did not charge me for any of this, because he said that he does not charge if he can't fix the problem. He was still pretty much 100% sure that the transmission would be the problem, but at that point he said the only thing that I could do would be to actually replace the entire transmission with a rebuilt one, and hope that doing that would solve the problem.
So... It seems that one of these things has to be true:
1.) All of these Transmission Specialists plus a certified Jeep Master Mechanic are all completely wrong, and the problem is not related to the transmission at all, and my transmission mechanic invested over 2 months of time plus the parts and labor required to rebuild the transmission and torque converter etc. based upon a wrong assumption that the transmission was the problem.
OR
2.) Somehow my transmission has such a rare and freakish problem that it was able to avoid being fixed despite the transmission almost being completely replaced.
I'll just have to keep searching the internet to try to find someone else who has experienced this obviously very rare problem.
Is the clunk/lurch when put into gear caused by a sticking slip yoke ever unidirectional? I found this video where GRAVITY was causing a unidirectional clunk/lurch. If gravity could cause the slip yoke to slide down the shaft when in Neutral, removing play unidirectionally, then it could cause a unidirectional clunk/lurch:
https://www.youtube.com/watch?v=DelqMr6Mmaw
GRAVITY only works in one direction, and if part of the drive train stucture has up and down play in it, that would explain how the clunk/lurch could be unidirectional, because gravity can serve to remove play unidirectionally when in Neutral gear. His differential support bracket was being lifted up when in Drive, then it would fall back down to normal position when in Neutral, leaving no play to cause a clunk/lurch when put into Reverse.
I guess the first easy step to take would be to park the XJ on a very steep hill in all possible orientations, and see if the clunk/lurch changes in any position. But if the part that is shifting up and down is actually shifting nearly perpendicular to the ground, then I'd have to suspend the XJ upside down to learn anything. If so, then I'll just have to mount a camera at various points in the drive train to see what is shifting up and down when I shift from Neutral to Drive and back.
Have you actually been under the Jeep when someone is shifting to see where the noise is coming from? If it that loud and that noticeable, you will have no trouble ascertaining what is making the noise.
As far as the slip yoke "sliding down" due to gravity. It cannot happen! The rear driveshaft is a single piece with end one fastened to the axle differential pinion, the other end slides on the slip yoke at the transfer case. The only time the slip yoke "slides" is when the axle cycles up and down, changing the distance between the axle and the transfer case.
So, get under it and listen/feel and report back.
