greenlawnjeeper
- NY
This condition only happens when braking and when you are almost completely stopped. Only does it on the passenger side. Did the brakes with new drums in December and all was OK till about a month ago. Used a rubber hose as a stethoscope and noise can be described as either "click, click, click" or "thumpt, thumpt, thumpt" and if the sound was coming directly from the rear end housing, I would swear it would be a broken tooth on the rear gear - but noise only happens when brakes are applied, and like said previously, the sound starts just prior to being almost stopped. The slower you go, the more noticeable the noise. No sound when car is running or while braking to a stop in reverse. Bled brakes a wk ago and sound seem to have stopped - sound came back and bled brakes yesterday with no effect. Pulled the drum and everthing appears OK Any clues? Vehicle is a '96 with 40K miles. Could it be antilock brake related?
