TheXJfiles
- Stokesdale, NC
Anyone know how to clear the engine maintenance light on the dash. Just got this truck with 87000 K on a 92 XJ and need to clear it.
TIA,
Dennis
TIA,
Dennis
TheXJfiles said:Anyone know how to clear the engine maintenance light on the dash. Just got this truck with 87000 K on a 92 XJ and need to clear it.
TIA,
Dennis
sjx40250 said:I have a 92. There is no "thing" to unplug except the light. The way you turn it off is to have someone hook up an OBD scanner and clear the code. There is a reason it is on and you should find out.
One way to do that is to turn the ignition key on - off three times, leaving it in the on position when you finish. Don't start the enging during this process. The Engine light will start blinking and you should count the times it blinks. The codes are two digits long so you may get more than one code. The blinking is in sets so three is three blinks with a pause. You may need to do it a couple of times to get the hang of it. Do a search and you will find a list of codes or look them up in the FSM.
