Clearing "check engine" light on 97
You can use a code reader or cycle the ignition 50 or so times.
Easiest way is to disconnect the battery for 10 or so minutes. Or get a reader that clears codes as well.
Keep in mind this resets everything, so if you have to pass inspection (like in MA) you'll have to have a few miles on it before they'll except it.
my CEL went on when #5 injector got too hot on my 98 and once i let it cool down and drive it awhile it went out.. I think if you correct the problem the compter will correct it self and the light will go out. It did it for me 2 times so far.
