Just chgd. tranny fluid again after 25K, with Castrol ATF+3??? I'm assuming this is fine for Dexron 2-3 orig. type fluid? It came out real clean again - didnt drop pan, no leaks. It's hard to tell how much I drained and a real booger tellin EXACTLY how much is in, I put in approx. 3.5 qts and it "appears" at COLD reading to register the equivalent of one hash mark high?? ie., same diff. as at ADD and FULL but on high side of stick. Apparently this stuff is so clean, I can't tell for sure when it's running exactly where level is???? Arghhhhhhhhhh. Cant they make it in BLACK??? Runs great, very few dust size shavings came out. Prob. next time I'll drop pan, chg filter and add inside magnet. It just didnt seem neccessary. Also installed new air filter, and Pennzoil 20/50 full synthetic motor oil. Thanks for any advice, Heinz
P.S. Also chgd, xfer case, was sparkling clean too.
