slujeeper5
- Chesterfield, MO
Hey everybody,
A few days ago the check engine light came on in my 73000 mile-ed 98. I checked the fluids, they seem ok. The light comes on when the key is in the run position, when the engine is not actually running. I did the " hold the odo button, turn on key then back off" trick and the number 2.3 shows up on the readout. My engine seems to run rough too, maybe its related? any ideas?
oh hey one more thing--
I had some work done while it was under warranty and they ended up replacing the rear driveshaft. I'm pretty sure they had the t-case apart while doing this, because at first they told me the internals of the case looked ok. But now, i get a knocking noise from the t case/t case linkage, and if i pust the lever forward or backward a little bit i get a grinding noise. do they all do that? thanks.
