chuck2000xj
- Ft Leavenworth, KS
Alright guys.....I am at a loss here. About 2 months ago, I had an issue. My radiator cracked when I was about 30 miles from home. Attempted to limp it home adding water constantly til I was about 10 miles from home. Where it decided to just quit. Got a buddy to pull me back to his place where we replaced the radiator. Right after doing this...I replaced all fluids, spark plugs, and valve cover gasket. Started throwing cylinders 2 and 3 misfire. Had a buddy check compression and 2 and 3 were low. So we replaced the head gasket, and again all fluids, filters, plugs, etc. Well, right as we got everything put back together, my water pump started leaking. Replaced that. Intemittenly after that the check engine light would come on and it would idle like shit. When it would go off, it ran smooth and strong. Well, i decided to replace the coil pack. Still no difference. Off and on. Well, a buddy told me about TSB 18-031-03 (Rough Engine Idle after restart following a Hot Soak). This seamed to explain my problem exactly. It would start to idle rough after a longer drive at highway speeds. So, I bough the heat shields and put them on injectors 2 and 3. This has been a week or so since they have been on and still no change, except the check engine light has bee on for about 1 1/2 weeks. Also, a few days before the heat shields went on, I Seafoamed the engine. i have no idea what is going on or wha the problem could be. Sorry fo the lengthy write up but I wanted t give as much detail and history as I could. Thanks guys.:smsoap:
