changing the jeep.......
how hard is it to actually do?...everyone is makin it seem hard...but it chouldnt be that hard(theres the jinx)
its not hard at all, but it is something you need to be very careful with because it can be really bad when it goes wrong. case in point i recently had a diff i built for a hmmwv go bad on me while on a road test. it turned out not to be anything i did wrong, what happened was the goober that put the diff's into the truck forgot to put fluid in it. they handed the truck to me to do a final inspection/road test and about 11 miles down the road the front diff completely locked up on me while doing 45mph down a country road. i still have the r&p on my tool box, i'll post up pics once i take them. the thing is, if you put it together too tight then it could lock up on you even with fluid. if you build it too loose then you can run into problems with the gears teeth bashing into eachother too much and the diff won't last nearly as long as you want it to, even worse a tooth could break off and then you are in deep doodoo. you also have to worry about the bearing pre-load on both the pinion bearing and carrier bearings. if they don't have enough preload or too much preload you run the risk of the bearing failing prematurely.
so while the process itself isn't that hard it does require a lot of care and attention to detail. you'll also want some special tools like a beam style torque wrench that measures inch/pounds, caliper, dial indicator, and case spreader. you'll also need some prussian blue, its a special paint you use to "read" the bear mesh after you're done. you then also need to know how to read the markings. you will also need tools for removing and installing the bearings and races.
i have a used set of stock 4.10's for the d30 and d35. you'd still need the carriers though as these axles use larger carriers for 3.73 and up. i know you're running the 8.25 now, but it would get you halfway there.
if frankz is unavailable when you're ready for gears i can set them up for you too. i've got all the tools and have done plenty of r&p's.
dutch -- I think Frank is looking for a set of D30 4.10 gears for Daniel's rig, if you haven't talked to him...
ooooooooooohhhhhhhhhhhhh.........
ya so i will end up needing some help.....
down the road....but....oooooohhhhhh is all i can say lol
mmmmmmm.....new tires!!!!
me gusta!...gonna prolly test em out on sunday with a run to eagle rock...oh ya!
ill post pics of them on jeep tomorrow when its actually light out
hahahaha im not sure it works quite like that...in fact i can get fired for that i think...but they can cut you some cost off...
i kow we have some MTR's at work (31x10.50's i think) that we got a KILLER deal on from our warehosue cuz its overstocked......
be tee dub
hittin saran wrap/eagle rock here in a few....
just in case ya wanna join....just me and a tj i believe:dunno:
got the full coils on now...jsut need to do the rear...benn kinda sick lately and workin 13 hour days doesnt help any...:puke:
but heres the pics for the front....
before
out
in
front view
after
:clap:
oh and before i get hung for it...yes...LONG arm kits is next..pickin up other jeep so as far as this one being stuck in first...oh well for now..itll only be on trail anyway...go until it breaks tehn replace it all...
i will get 35's once i regear....probably not til like february time reame...but at that point ill probably sell rims and tires...and teh tires should all be almost new...(imma have some really bad luck and need em all replaced lol)
Lookin good!!:yelclap:
