cb placement
dfreeman616 said:
here's what i use to have in mine, just a temprary set up that can be pulled out in less than a minute and put back in. uses zip ties between the bracket and the clip.
Looks clean...
I put mine in the overhead console. I'm not done with the wiring...where did you guys go for your 12v? and I plan to run the antenna coax up in the headliner, and pull it through to the hatch. I've got a no ground plane antenna to mount on the hatch. I may turn the radio around, although I like the mic cable pointing forward, and the speaker pointing back.
CB in overhead console
