CB in dash mount?
iwannadie
Gilbert, Az
I hate posting this but searching for CB info is tricky.
Has anyone done an in dash CB mount under an aftermarket normal radio mounted.
I've seen one or two pictures of one mounted but hard to see how it was done.
For a 97 style dash...
Check this out.
http://www.cobra.com/products/recreational/c-75-wx-st
No big hole, no hassle. It works good.
this.
There's enough room to the left of the gauge clusterl to fit the box, then you can drill a hole in the center stack bezel and pop the wire through it's grommit.
When you don't use it you disconnect the handset and put it away and all you've got left is a shiny connector in the side of the dash. Very clean.
