frozen chosen
- North Dakota
I have the R/C 4.5 and was wondering if I should have had my caster adjusted when I installed the lift or do the LCA that come with that kit compensate for that? I had an alignment done after installing the lift but no adjustment was made to caster angles. The reason I am looking into this is that I have a vibe coming from the front end and I am going to remove the front D/S tonight to see if that is my problem but I live in ND and don't want to go without it for more than a day since we are setting all time snowfall records and I don't want to have to need it with it being out. my vibe is from 50mph on up. I have a SYE in the rear and did not lower my TC when I did the install. HP 30 in the front. Do I need to put the TC drop on the rig? Any info would be great before I go without a DS in this snow.
