Cars, motor, jeep parts etc.
Bouncy
Flat Rock, MI
FS: 1964 Nascar Hemi Complete motor
Item Description: 1964 Nascar Hemi Complete motor
Price: $18,000
Contact: PM me here OR jeepcj7 at gmail dot com I can provide phone contact after email contact is made.
Only serious buyers please.
This motor was built by Dean Nicopolis. Google his name for history of him being one of the orginal Ramchargers.
This is a 1964 iron block factory dated 1964 and produced with 1/2" main side bolts. Limited quantity produced for NASCAR. Heads are A990 option cylinder heads as supplied on 1965 race cars by the factory. Intake manifold is a 1996 new design aluminum crossram. Also a second intake Rat Roaster model orginal dual quad inline setup. Full radius crankshaft with orginal hemi connecting rods. Pistons are TRW with custom machining to remove weight and match cylinder head valves and chamber. Cam is a billet roller camshaft and comp cam lifters solid roller. Sealed Power rings with .031 dykes top, cast iron second and 1/8 oil ring (3pc). Light weight sprockets with roller chain cam drive.
Engine Specs.
Bore 4.311"
Stroke 3.750
Compression Ratio 12:1
Valves intake 2.2 exhaust 1.940
Stock hemi valve train, intake rocker 1.57:1 exhaust rocker 1.53:1.
Camshaft 292-04 .750 theorotical lift, actual is .715 install at 103.5 degrees at valve.
Valve lash .030 both intake and exhaust hot or cold.
Valve springs K-Motion 1000h
Engine operating range 2000-7500rpms max.
Pics Located Here: http://s197.photobucket.com/albums/aa247/youtube72/Hemi/
_____________________________________________________________________________
FS: GLHS #223 1987 Charger
Item Description: 1987 GLHS Shelby Charger #223 1 of 1000 Car.
Price: $9,995
Milage 33,146 Original Miles
1987 GLHS #223. Car is completely stock. New paint job. No rust. I lifted the carpet myself...Absolutely NO RUST other than the muffler. Miles...33k. Engine runs good. Turbo still pulls strong. Completely stock and orginal...just fresh paint, decals, and new headliner. No smoke from the motor or turbo.
To complete the car off, it needs a hood prop rod, rear hatch seal, battery, rear hatch shocks. Gas gauge appears to be disconnected for the moment. To make the car perfect, it needs a drivers side rear interior plastic side. The current one is scuffed.
Pics Located Here: http://s197.photobucket.com/albums/aa247/youtube72/GLHS/
FS: GLH-T 1986 Omni
Item Description 1986 Dodge Omni GLH-T Turbo
Price: $3,000
Milage 71,816 Original Miles
1986 GLHT Omni. 2.2L motor rebuilt by previous owner. Has 500 miles on it. 555/520 hybrid tranny with OBX, large equal length axle shafts, newer performace brakes all corners, newer suspension, Rusted floors cut out and welded in new metal with truck liner coating. Car does need some work still but $1500 put into tranny alone with new 2 and 3 gears, new bearings, drain plug upgrade, new seals etc.
The bad. Headliner is falling in needs recover. Rear hatch shocks shot. Rear wiper needs new motor. No stereo or speakers. Minor work to put interior door panels back on the doors.
I also have a ton of extra parts I was going to use for build up. IF you buy the car, you have first option to purchase the parts. Teaser: 2 piece intake, GLHS gauge cluster, bigger throttle bodies, bigger injectors, 2.5 short block and G head...Just to mention a few things.
Pics Located Here: http://s197.photobucket.com/albums/aa247/youtube72/GLHT/
Motor Specs and parts installed by Previous Owner:
Small parts package
Sintered Iron Rocker package
Hardened valve locks
Race valve springs
Viton valve seals
Chrome moly spring retainers
185 degree thermostat
Heavy duty motor mounts
Race head gasket
Turbo race injectors
L body 14:1 ratio rack & pinion
MSD ignition
Front and rear wheel bearings and seals
New sensors and soloniods
High volume race oil pump
Oil cooler
Stainless steel valves
Moly race rings
New lifters
K&N filter
Federal mogul hypereutectic pistons
Camshaft, seals, gaskets…CAM is Pictured.
New front and rear shocks/struts
New belts, hoses, plugs NGK V-power, wires magnacore
2.5” stainless steel exhaust
New rotors, brake lines, calipers, wheel cylinders
Raybestos blue stop pads and shoes
Parking brake cables
Momo steering wheel
Garret T-3 turbo with cooling and oil lines
Bosch starter
TRW heavy duty water pump
Derale cooling fan
782 fast burn head
New ball joints
New tie rod ends
Rebuilt CV joints with new boots
FS: XJ CJ YJ Parts
Item Description Misc Parts
Price: Listed with each part
Lots of Parts - 4.0, CJ tops, doors, rolling chassis, howell efi, many more
1995 4.0 long block. Assembled head and block. ~ 45k miles, new pickup, oil pump, needs 2 head bollts and timing cover bolts but the seal was never broken $400
Bestop CJ7 soft top and doors. Looks like all hardware is there, but I'm not positive. $500
F250 lift coils, good for about 4" of lift on XJ $50
CJ7 hard top with rusty tailgate $50
XJ nerf bars $100
CJ7 rolling chassis - 304/4 spd manual/d300 on stock axles. no rims/tires $1200
Howell EFI for AMC engine, can probably be used with any V8 smallblock $800
Surco XJ roof rack $100
bunch of H1 tires ~ 36x12.50x16.5" $20 each
6 H1 rims with tires mounted 8x6.5 lug pattern 8 lug Bead lock with magnesium run flats- won't separate rims and tires $700 for 4 and $800 for 5
YJ soundbar without speakers $25
tons of D35 drums $5 each
'90 4.0 head $75
1 '90 intake and 2 '95 intakes for 4.0 engines - $30 throttle body & injectors, $25 injectors only, $20 intake only
4 33x12.5x15" Pro Comp Xterrain tires $500
4 XJ front driveshafts $40 each
YJ rear dshaft $15
built dshaft XJ length with longer YJ slip yoke $50
7 batteries good for cores $2 each
good rubicon and XJ batteries $25 each
340 forged crank, actually a .331 stroker from a 273 $250
pile of misc shocks $5 each
FS: Bird Cage
Item Description Large Bird Cage
Price: $450 OBO
Link to product: http://birdcages4less.com/Merchant2/merchant.mvc?page=B/PROD/Medium_Bird_Cages/PA5743
Local pickup or buyer pays for shipping.
Black Flake Color
Puna ParadiseTM Hybrid Cage
42" X 28" x 73"
FEATURES:
*5/8" Bar Spacing
*4mm Bar Gauge (perfect for greys/amazons!)
*Total (floor-top) Height (Convertible Side) 73"
*Total (floor-top) Height (Playtop Side) 56"
*Inside Height (Convertible Side) 62"
*Inside Height (Dometop Side) 36"
*Convertible side opens into play area.
*Durable, non-toxic, powder coated paint finish.
*Horizontal side bars, Vertical bars front & back.
*Front door bird-safe latch.
*Panel opens onto playtop side to allow bird easy access outside.
*4 swing out feeder doors with bar that holds dishes in place.
*6 SS cups.
*4 dowel perches.
*Included, optional, seed catcher (add 3.5" all around to stated
dimensions).
*Large front door for easy access.
*Slide-out grill & tray for easy cleaning.
*Slide-out tray on playtop side as well.
*4 easy rolling casters.
*Knocks down for compact storage.
*Perfect for African Greys, Amazons, and similar. Not suggested for Macaws
(due to the depth of the cage, and the playtop side height.)
FS: Pool Table 6ft Slate
Item Description Pool Table dismantled 6ft 3 Piece slate with sticks and cue balls
Price: $100.00
This is a 6ft table 3 piece slate. It was dismantled before trasport. It comes with Sides, Rails, Pockets, Sticks, Cueballs, Slate, Legs, and misc pieces. Should be complete, may need a bolt or two.
I don't have a brand or model, nor instructions on assembly.
FS: 16ft Pool with blow up top ring
Item Description Pool 16ft round. Blow up top ring. About 42" deep Many extras added on.
Price: $200.00
This is a 16ft round by 42in deep pool with ladder. Exact model: http://www.walmart.com/catalog/product.do?product_id=3905322
Extras purchased: Extra washable filters, chemicals, hose for vacuum, better vacuum head, skimmer screen, skimmer handle, hanging skimmer with attachments to filter. Roughly $150 in extras alone.
