Carnage report
GI-John
Mount Holly, NJ
I just got back and had a few issues as some of you know. Here is the preliminary report:
1 bent ZJ tierod
Rear leaves lost about 3" of lift
Exhaust separated from the header (easy fix)
Broken exhaust hanger
L/R brake pad keeps sticking/
Thanks to everyone that helped out: it turned out that I was able to adjust my tierod so that is wasn't so boogered and drove it home with no other issues. (Hans, I'll get your stocker back to you soon)
P.S.
my 6" aluminum blocks broke pulling into the parking lot:flame: ;)
John
1 Brake Booster elbow
1 ARB fitting/1"of hose
1 O2 sensor
1 goofy clanking from front end the entire way home. (U-Joint or shaft is all that's left to investigate_
1. 38" tow rig sidewall (about a 1foot square section).
2. very slight dent from a "kiss" with a tree from my pass side front door handle.
Michael
Got a new dent.Dang Tree wouldn't move out the way.
Got some new noises to.my heep sounds like a haunted house.
poped my back window out Fri. it stayed there just had to put it back in the window gasket.
JACK
1. Passenger side mirror
2. CB antenna
3. Aussie making a lot of noise now I'll investigate when I get back from Oregon later this week.
1 missing trac bar bolt and one really loose TB bracket
1 smashed winchline thimble
mystery dent in RF fender.
Mud and dust in places I didnt know existed.
-Ryan
Michael
1. One night's sleep. See #1 above...
1. Rear transfercase output seal
2. Scratches from rock in passenger doors.
3. Dent in passenger rear quarter panal, no idea what from.
4. One very clogged air filter, I highly suggest everyone replace theirs or clean it real good. I have never had a filter that dirty before and it was spotless before the trip.
I stayed home but I have some carnage too.
1. Melted/Shorted wire to the AZC controller for my heaters blower motor.
You should take one trip to Pomeroy, WA...
One rally up there and Jeff and I had some seriously nasty air filters.
mud1059 said:
That is a good point, what happened to your sidewall Michael? Road debris? Jersey barrier?
I don't have a clue yet. I will be taking it in today to have it looked at and hopefully get some understanding. I have never seen anything like it before and when it happened I had no clue it was the tire. I didn't hit anything but it was a rough section of road (I-90 just outside of CleElum).
Michael
Cooling system is pretty much shot
Knocked out a mirror (still intact though)
Took alot of paint off my flares and tree sliders
Put a hole in the sidewall of one of my BFG's
Destroyed my centering pin on the drivers side rear leaf which moved the whole axle and bent up a shock pretty good.
Wheeling is awesome :D
-Alex
Mine is hardly worth mentioning. Lost a flair at funnyrocks, and stuffed my fender.
