Ecomike
NAXJA# 2091
- MilkyWay Galaxy
I am actually hoping to take the PE exam shortly. You can do that even with not having a degree, but you do have to demonstrate proficiency and years of experience.
IIRC Texas closed the loop holes back in the mid 90's here. Now it takes an ABET accredited 4 year engineering degree (not a tech degree!), minimum, to apply for a PE license, several years of practice under a licensed PE, and 2-3 PE recommendations. They do let you take the PE fundamentals exams just before or right after graduation from an ABET accredited engineering college. I forget the details, but IIRC there is a final review board approval required, and a final practice exam of some kind required.
I think, unless you are dealing with the public (which was a big part of the trumped up issue on this one), the PE license is mostly a pay grade and reputation credential. You do not need to be a PE to teach engineering courses at a university, but instead a Ph.D. in the topic is required (with out the PE), unless you have a PE licensee, and probably at least a masters degree in engineering, and are a specialist in a new field, or sub-field. IIRC I did have one or two PE engineers with just bachelors degree teach a course, but it was very rare. Several had Ph.Ds in engineering, but were not PEs.
I was planning on going the PE route in 1996, but never got around to taking the exams, and never needed it. My father was a licensed PE in 48 states (he got bored easily, LOL), in civil, electrical, mechanical and plumbing. He made his living his last 25 years doing civil engineering for builders (K-Marts and JC Penny stores, which I did some early drafting work on when I was 19...many,many moons ago). His last 10 years were as a consultant to Aramco and 3DI. That was where I got my early intro / education in the fields.
Old_man is right about this:
"Actually from what I have seen over the last 40 years, you can't call yourself a PE without the PE license. A non-degreed engineer has the right to call himself an engineer but in a contractual situation it needs to be set forth that he is non-degreed"
I might add that the key point is whether he or she is a PE Engineer, or a non PE, Engineer.
