Skitzo
- Louisville, KY
anyone know what the cannister inside the bumper on the passenger side is? it's a 91 xj, btw.
ChEwBaCcA said:The MOST important reason NOT to remove it is......because if you lose your motor for some reason it will provide enough spare vacuum to get 1 or 2 power assisted stop out of the brakes.
Could be the difference between running into a wall or rolling to your death!
Regards
Chewy
Matthew Currie said:Unless I'm quite mistaken, the volume of the canister, the bore of the lines, and the placement of various check valves, make it a non-contributor to brake boost. This is why brake boosters themselves have a big canister of their own, which is dedicated to the purpose. Thank goodness, otherwise all of us jeepers whose blimps have cracked, or lines corroded, would have run into walls and died long ago!
RINGKONG said:Hmm... my brake booster just get's it vacum fromt the intake manifold... no canister.. even if it did lose vacum... brakes would still work, just have to push on the brake harder...(I ran with out the booster hooked up to vacum for a week... never again, my right leg is now larger than my left... )
RichP said:Be nice if you could find a nice aluminum one similar to the one you can use for an overflow bottle.
RichP said:I have not seen a newish vehicle that has AC and Cruise that does not have a vac cannister. If you need a new you might want to see if they make them in different shapes that might fit better inside the engine compartment. Curious, is the vac bottle just a bottle or does it have something inside that divides it in half, IOW vac side/pressure side ?? I've never taken one apart or seen a mashed one... Be nice if you could find a nice aluminum one similar to the one you can use for an overflow bottle.
