Can you ID this rear end?
JohnX
Sarge
Williams AZ
Should be mid 60's to early 70's vintage...5x4.5 bolt circle, Has lug bolts instead of nuts...but that could be someone elses doing?
This is on a very small trailer and has bent axles...the reason I need to know what to get from the junkyard.
Thanks to the winner:D
Looks like off of an old Toyota pickup
Holly huge pics batman!
Yeah, looks like a toy axle to me.
But 5 on 4.5? Did they come with that? Im guessing yes, cause it sure looks like a Toy axle.
Yeah they did come with 5 on 4.5, i also believe they came in 6 on 5.5...maybe just later on....?
Lug bolts instead of lug studs? Do the large "bolt heads" on the back of the backing plate move the shoes in and out? Are the drums held on with a large nut and keeper pin?
Looks like an old MoPar 8 3/4 drop out rearend. '40's to early '60's?
Got one under my '49 half ton.
My 72 Celica has the same rear end, just checked, also if im not mistaken HILux Toyota trucks came with that. Good luck finding parts for it. If im 100% right, and you need axles, www.classic-celica.com is your place. HTH.
It looks alot like the orginal rear end from my dads 41 plymouth pickup. It had lug bolts instead of lug nuts and one side is left hand thread and the other is right. It was a 5x4.5 bolt cricle and had two piece axles.
