Can someone help with Axle ID/I need 1
brothrDave
dublin,ca
out of my Dana 35 I'm looking for another for emergency trail repair with the bearing and housing together so I can carry it w/me just in case so I don't do the same damage I did last time it broke Can someone tell me what vehicle it could have come from so i can junk yard find it I can not find 1 thxs Dave
You would be better off going to a junk yard and getting a Chrysler 8.25 from a cherokee and bolting it in. Or if you can do a little welding, a Ford 8.8 from a 95 or newer explorer which will get you disc brakes also. Much better axles and you will never have to worry about that crappy D35 again. That looks like a non C clip D35 so if you really want to find the parts you will need to find a cherokee in the same year range as yours to get the correct parts. Car-Part.com will help.
I believe the Dana 35 without c-clips came in 1984 to 1989 Cherokees. Are both axle lengths the same? You may need to carry both sides if the pumpkin is offset and the axles are significantly different lengths.
thank you both axles are the same lengths and I know I need to upgrade to a stronger axle but $$$ has already been spent on replcement parts for broken 35 and it did work good for 4 years since I bought it thnxs for the info I will be off to junk yard today to look around thank you
The Pick in Pull at the end of Mowery Ave in Fremont usually has a good selection of cherokees to choose from.
I have a non c-clip dana 35 I pulled from my 89.
Yours if you want it!
The gears are shot, the most of the bearings are shot, but if you need some spares...
