Can I Put This Head on a stroker?
BBeach
Worcester
Would putting this on (http://rustysoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ALUHD&Category_Code=HP) with (http://rustysoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=RRR-205&Category_Code=HP) work? If so how much power would you expect and would it make header and intake numbers rise as well? Also, could you put that head on a stroker?
Im basically trying to found out how i can get as much power out of my 4.0 as i can. I figure gettin a 99+ intake manifold from junkyard and Banks headers at same time should be good for around 30 or so then a few more things. Any ideas?
i dont see that aluminum head possibly being worth $1600.
I do like the roller rockers cause the stock pressed arms look puny and shitty and although the performance gains arent huge from the roller rockers in the aplication like a 4.0 its not a rip off. Its a good product.
I think i would spend that $1600 on a something else than the head. Get a stock head ported and polished and thats it.
there are a few outfits selling roller rockers for closer to $300 and one of the sets recquired some machine work to be done, and i think a valve cover spacer, and a few others worked fine right out of the box.
So if they meet your standars you just saved $1,700 now.
Gitter done
