I have them on the wife's DD (street only), but I removed all flares and trimmed the fenders. If you plan on wheeling stock with 31's you will have to bumpstop alot or be prepared for fender and tire damage. You should also expect to rub the lca's at full lock if you are running stock backspacing.
I've run them for a long time. But as said before there is a rub on the rear over bumbs. If you don't want them to rub 30's are as big as you can go stock.
