can i bypass the headlight delay module???
sofixj
Edison NJ
ok just like the title says can i bypass the headlight delay module in my 1997 cherokee sport. its got power going in but nothing comes out and im not have ing any luck with jy ones.... i dont use the feature so i will not miss it...I just need headlights back cause i dont have any. no low beams or high beams. No high beam indicator either.
help guys i work nights and need my jeep back
:NAXJA:
Info from DJ
Jeep Headlights stay on why
If you turn off the ignition before turning off the lights, they will stay on for 45 seconds as a "security measure," so you can get the door to your house open while it's still lit up or something stupid like that. Chrysler designed it this way this is what the Headlight Delay Module is for.
If you turn off the lights before the ignition, this won't happen or just cycle the key on and off again and the lights should go off.
I don’t think the HDM has anything to do with your headlights not turning on.
It is more likely that you have either blown a fuse or have a defective main headlight switch.
I hope you didn’t replace your regular headlights with those nice bright headlights that are on the market, because if you did that is your problem. Those lights use more power than Jeep & a lot of other cars on the road were designed to provide and require a complete headlight electrical upgrade.
Hope this information help. Post back if you need more help or what you do to solve the problem.
I agree that the HDM should not prevent your headlights from lighting. You can simply unplug it.
Where did you check for power?
