- Colorado Springs, CO
Hey guys,
I'm building an HO/Renix combo engine. The engine will be a 91 carefully rebuilt with a good valve job, haven't taken it apart yet so I don't know about piston size yet. Mr Flores, who has built quite a few 4.0's will be in charge. I am keeping my Renix intake, with bored T-body, and Mopar/Mike leech header to 2.5" exhaust. As I mentioned in another thread, the bored T-body really woke up the tired Renix engine. I'm thinking with the better flowing HO head, it should be even better. I was going to fool with another Renix head, but at this point the bottom end has been through 3 rear main seals, still leaks, so I figured might as well just do a rebuilt engine with the HO head.
I'm looking for a cam that pulls strong to 4500 rpm's. I'm not so worried about the bottom end, I've got plenty of gearing for the trail, although it would be nice to have some pull from 2k rpm. Right now going uphill in the Mt's, if it's under 2500 rpm, I will end up dropping a gear.
I don't know if I've ever posted the spec's. It's a 90 XJ, with a 96 AX-15, 241J, HP-30, D-44, 4.11's, assorted lockers, 33's, and quite a bit of extra steel, because added weight helps performance.
It's a daily driver, but doesn't get driven much. I would like to be able to trust it to take longer road trips than just to Moab. Obviously it's built to be a wheeler, but not a trailer queen. I do have a M416 trailer with roof top tent in the airstream that I tow every now and then.
Thanks.
Thanks.
