Fred85
- Orange, VA
nevermind
ECKSJAY said:
Angus said:I used the JKS spacer and even though I weld, I had a professional weld them on. I also used the JKS draglink, tie rod, and tracbar axle relocation bracket. The tie rod ends are stock WJ for now, but if I switch to true high steer I will have to get one right hand drive end for the pitman arm end. I bought my knuckles used from an online yard ($100). My rotors are Advance Auto's higer end WJ 2003's with the bolt pattern redrilled. The calipers I used came in a "update kit" from DC ($150). The kit included 2003-up calipers, pads, brackets, and all the small hardware.
One drawback of using the bearing spacer is reduced bearing to knuckle contact or indexing. The three bolts are not realy meant to hold the whole load. In that regaurd I made a bushing thats OD fits snug to the inside of the knuckle. The ID fits snug to the bearing on the inner tappered part of the bearing housing. If anything it makes me feel better that there is now more of a fit to the two parts rather than just atachment.
Angus
Angus said:One drawback of using the bearing spacer is reduced bearing to knuckle contact or indexing. The three bolts are not realy meant to hold the whole load. In that regaurd I made a bushing thats OD fits snug to the inside of the knuckle. The ID fits snug to the bearing on the inner tappered part of the bearing housing. If anything it makes me feel better that there is now more of a fit to the two parts rather than just atachment.
Angus
T&A-XJ said:Im not sure on the 2000 or so part difference but I think cast rotors use the mid 90s dimension hub and the composite rotors use the pre 90 dimension hubs.....correct me if wrong.
