C&C hubs on a SRW 14 bolt with discs- enough room for XJ spring perches?
Ya I ordered the front lines and plan to run that to the T at the stock style soft line in the rear, I like the idea of the soft line at the center
so the calipers wont clear unless you have a decent pinion angle with the RS brackets. luckily I am fine but it all barely clears. it wouldn't clear if you had like a 0* pinion angle
So did you figure out what axle you actually had?
From what I read, you cant really do a disk swap on a C&C axle. The backing plate mounts are to narrow for the normal bolt on disk brackets.
The C&C and SRW axles are the exact same, with the exception of the backing plate mounts.
A SRW and C&C will both have the 63.5 WMS to WMS with the C&C hubs. Or, 67.5 with the SRW hubs (The C&C hubs remove 2'' per side compared to the SRW).
Did any of that make sense? :wierd:
The previous owner said it was a srw with hubs so I ordered the ruffstuff srw with dually hubs brackets . It's a very close fit .
