jeepgeek2002
- Jax FL
Grand cherokee's have issues like that constantly.. its 99% of the time ECU related. changing the computer fixes it. Did you swap your ECU out?
sounds like a bad/mis-adjusted ignition switch. The items you lost are on different fused circuits, but are all powered through the ign. switch. Because shutting it off and turning it on corrected it, I'd say it is slghtly out of adjustment.
If you're going to take the time to replace the pump, do yourself a favor and get something OEM. I wouldn't recommend an Airtex...and this is coming from somebody who sold them for 2 years.
Fuel pumps are one of the very few items I do not cheap out on. I've had excellent luck with OEM's from NAPA for any vehicle i've put them in. They're usually Bosch brand as well.
Why the hell did you sell me one then?
And besides, it's not like you really drive your Jeep anyways...hahahaha:laugh3:
As of right now, I start the Jeep up (with the old pump) and its sitting right at 48psi. Seems good. When I cut it off should it hold that same pressure for an extended period of time? Within 10 minutes it's all the way back down to 0psi. (I know that's not right) Primes right back up. I suppose that's to blame on the infamous check valve in the pump assembly...
