"Burping" a closed system
jbt114
Long Island, NY
I'm having my cooling system flushed in my 89 XJ by my mechanic. I asked him about "burping" the system to avoid air bubbles.
He mentioned removing something from the rear of the head, I believe, to force the air out of the system.
Does this sound right?
I think I remember reading about jacking up a certain corner of the Jeep to help to raise the bubbles to the top.
Anyone know anything about this?
Thanks in advance...
Chris
pulling that sensor can be a pain, i have one of these t's installed in one of my heater hose (couldnt tell you which right about now though) , seems to work.
now that i think of it, that sensor might be easier to do without scalding yourself
Hello All,
For those of you, that do have the T-fitting in one of the heating hoses, replace the plastic screw on cap with a brass one (same as a garden hose end cap).
I had the plastic cap for a few seasons and just buy chance, I looked at it one fall day, and to my astonishment, the top of the cap was so thin, failure was imminent. I posted this a few years ago. I hope this helps someone.
62tmar
Hello All,
62tmar
The cap failing on those Prestone Ts is so common it is not IF but WHEN. I stopped using them a couple decades ago.
I went the next step - and made the whole T fitting out of brass plumbing odds & sods. 3/8" pipe nipples fit neatly into 5/8" hose.
