Bumper mounted shackles?
bics90xj
I can't find any pics or write-ups. My leafs are a bit longer than expected. Even with boomerangs they bottom out on the body. Thinking about doing a rear bumper with shackle mounts. Other Ideas are more than welcome.
Just make sure you use more than the stock mounting locations... those 8 bolts won't do much the way they're situated.
Tie into the hitch/tank skid mounting holes as well and you'll be better off.
HD off road shackle relocation brackets!
x2
Brian has long leafs on his rig and just uses the last hole with a set of shackles.
Don't you have longer leafs Glenn?
Yes, I use the f150 main leaf.
If you're going to mount your shackles on your rear bumper the only way I personally would do the bumper mounts is like foxwar71. I'm going to copy his mounts just for the fact it's going to be pure overkill and I know I'll never worry about them again. After watching him drop off a ledge and bending his uni-body I know they're more than strong enough for my application, and your's also.
http://naxja.org/forum/showthread.php?t=993533&highlight=bumper+build
